Activity › Forums › Apple Final Cut Pro › “render and replace” for audio
  • “render and replace” for audio
    Posted by Richard Herd on August 9, 2019 at 5:46 am
    Hello,
    Is there a way/workflow to render and replace an audio clip? I received a premiere pro xml and archive, but much of the audio was 44.1 although the sequence was 48k. This appeared to cause a sharing issue (but when I sent to compressor the issue was solved).
    Related, the 44.1 clips were all the production audio (dialogue) as attached clips and not managed very well in premiere. Then as I collected them into roles, I combined the roles into compounds. When FCPX creates compounds does it render/transcode them into the project settings–which in this case meant rendering 44.1 to 48k?
    Rich
    Richard Herd replied 7 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
