Activity › Forums › Apple Final Cut Pro Legacy › Render and Export Settings for Large-Form Exports
  • Render and Export Settings for Large-Form Exports
    Posted by Baird Reese on December 11, 2013 at 3:11 pm
    Working on a 2 x 2.93 GHz 6-Core Intel Xeon Mac Pro with 24 GB RAM — for Final Cut 7.
    I have a feature I’m outputting and was curious if there is anything I’m missing to optimize my output time.
    Footage: Pro Res 4444
    TRT: 85 mins.
    Sequence is defaulted at 8-bit YUV. I have in-to-out light green Preview bars. I go to output and get the Error, so I go to render, 2 hours. Crap. I change the render to RGB. Light green bars gone. Strange because I thought Pro Res 4444 was YUV since it comes out of the camera (ALEXA) with a Rec709 color space.
    Okay whatever. I go to export. Straight Quicktime Conversion. 2 hours.
    Does this sound right?
    After this I need to compress it down to an H.264. Is there a better way to do this instead of outputting a master and then bringing that into compressor?
    I tried going straight to Compressor last night but after 11 hours it was still chewing on getting this fat bastard into an H.264.
    Thoughts welcome.
    Thanks.
    Shane Ross replied 12 years, 9 months ago 3 Members · 2 Replies
  • Nick Meyers
    December 11, 2013 at 3:57 pm
    “Footage: Pro Res 4444
    TRT: 85 mins.
    I go to export. Straight Quicktime Conversion. 2 hours.”
    assuming this is 1920×1080 @24fps
    that’s a 160G file you are creating there, so yeah it doesn’t sound too far off
    “After this I need to compress it down to an H.264. Is there a better way”
    yes, export as a reference file, non self contained.
    THEN run it though Compressor.
    nick
  • Shane Ross
    December 11, 2013 at 5:23 pm
    DO NOT do Quicktime CONVERSION…that’s recompressing the file. Either QT Movie, self contained (for a full res version of the show, in a single file)…to archive and use to convert to H.264…or Reference movie to use to convert.
    Shane
    Little Frog Post
