Activity › Forums › Adobe After Effects › “Render and email” to gmail?
Posted by Eliezer Cisner on January 20, 2009 at 4:49 pmHello everyone!
I have a little problem with the script render_and_email.jsx on sending it to Gmail. What am I supposed to write as the smtp address? I tried to enter smtp.gmail.com, but the email failed (I don’t know if the specific reason is the smtp server address).
This is what the dialog says:
Script Alert
Unable to send email.
TypeError: null is not an objectPlease help!
Chris Orcfilm replied 7 years, 11 months ago 9 Members · 17 Replies -
Dave Fraser
January 20, 2009 at 5:37 pmhi, i use a similar script and send it to a hotmail account once. in the 1st email window you have to type your server address. if you go file/scripts/email_setup.jsx it’ll tell you what that is there. and then in the 2nd email window you type in your email address, blahblahblah@gmail.com
hope that helps
Dave Fraser
Motion Graphics Artist
Big Button
http://www.bigbutton.tv -
Eliezer Cisner
January 20, 2009 at 5:48 pmThank you Dave for your response!
As far as I understood your answer, it didn’t quite answer my question, or maybe I just didn’t understand it.
Let me explain my problem:
I have a Gmail account, and I want to send an email to my cellphone when the render completes. What do I have to write as the smtp server address? I tried smtp.gmail.com, but the email somehow failed.
Maybe that’s not the problem, but what can be the problem??
Best regards,
Eliezer -
Curious Turtle
January 20, 2009 at 7:41 pmIt could be that Gmail uses a different port than the script is expecting. Have you tried smtp.gmail.com:587?
Just a stab in the dark, as I haven’t used the script myself. (I might just do it now though!)
Cheers,
BenCurious Turtle Professional Video
Training | Editing |Support -
Eliezer Cisner
January 20, 2009 at 7:52 pmThank you, Ben.
I tried smtp.gmail.com:587 but it didn’t help.
Please help. Thanks!!!
Deleted User
January 20, 2009 at 10:12 pmHello,
Try this:
smtp.gmail.com:username@gmail.com -
Deleted User
January 20, 2009 at 10:25 pmHave you tried using an SMTP: such as you@yourdomain.com rather then a freebie email account?
Paul Hennell
January 20, 2009 at 11:18 pmHave you checked in the preferences that “allow scripts to access network” is checked? If it isn’t that might be causing the problem.
Only in after effects do children get to pick and whip their parents.
https://hennell-online.co.uk
