Activity Forums Apple Final Cut Pro Legacy render all yuv in high-precision yuv
  • render all yuv in high-precision yuv
    Posted by Richard Blakeslee on May 19, 2006 at 9:05 pm
    Hello,
    I’ve been using FCP for about three years. Today under Sequence/settings/video processing/
    I saw the choice of
    Render in 8-bit YUV was checked
    under that was another choice
    Render all YUV material in high-precision YUV. (higher quality results, longer render time)
    Is this worth checking? Have I been short changing myself?
    Thanks, richard
    G4, Dual 1 gig, 10.2.8 FCP 4.5 1 gig RAM
    Richard Blakeslee replied 20 years, 3 months ago 3 Members · 3 Replies
  • John Pale
    May 19, 2006 at 9:10 pm
    For graphics intensive material you might notice a difference, otherwise you might as well use the standard setting.
    Do some tests and see what you think. It’s really dependent on the material and your judgement.
  • Al Davis
    May 20, 2006 at 12:33 am
    Aso be aware that you have similar options if you use Motion. If you produce graphics in Motion at 16 or 32 bits; and then bring it into FCP and render at 8 bits, you will not benefit.
    Al Davis
    Visual Velocity
    Brookline, MA
  • Richard Blakeslee
    May 20, 2006 at 1:51 pm
    Thanks John and Al. A simpile idea. Try each and see the difference.
    Sometimes the simplist things escape me. (Good point about Motion)
    Richard
