Activity Forums Apple Final Cut Pro Legacy Render All running slow
  • Render All running slow
    Posted by Matthew Millsap on March 6, 2011 at 7:05 pm
    I’m running a Mac OSX 10.6.6. 2x 2.4 GHz Quad-Core Intel Zeon, 6GB Ram. I still have plenty of storage on the computer. (Over 600GBs). I’m running FCP, and I am running through a couple different videos. I want to splice together good parts of each video. But I have to “preRender” to preview it. It used to take a couple minutes to render out so I could preview withing FCP, but now the same amount of work requires over an hour to preview. But on the good side, when i do my final render, it takes a lot less time. I there a setting that needs to change? I only need to preview, not fully render just to see what I’m working with. Has anyone else had this problem?
    Matt
    Richard Cooper replied 15 years, 6 months ago 2 Members · 1 Reply
  • Richard Cooper
    March 7, 2011 at 6:39 am
    You need to set your sequence to match you footage in FCP. When you drop your first clip in the time line, FCP should tell you that “the sequence does not match you file format, would you like to change your seq to match your video” (or something similar to this, anyway) Click yes and no more rendering…. unless of course you are trying to put a non supported file format into the time line, then you would do best to trans code everything to ProRes first and then import and edit from there.
    Richard Cooper
    FrostLine Productions, LLC
    Anchorage, Alaska
    http://www.frostlineproductions.com
