Activity › Forums › Adobe Premiere Pro › Render AE (After Effects) linked project in Premiere Pro (CS5.5)
  • Render AE (After Effects) linked project in Premiere Pro (CS5.5)
    Posted by Brian Berneker on August 14, 2011 at 11:51 pm
    After my less than amazing experience with FCP X, I’ve decided to try and get more familiar with Premiere Pro.
    Given that one of FCP-X’s major selling points it round-trip workflow with Motion (which I never use, since AE is way more powerful) I have a particular interest in round tripping my Premiere workflow with After Effects. I’ve been able to place an AE project/comp into the Premiere timeline but it does not scrub well because it is of course not pre rendered (like it would be in less integrated workflow where only output rendered clips are used).
    Is there a setting or something I can click to force Premiere to render linked AE clips (preferably in the background) so that I can (eventually) scrub it live while editing the rest of the project?
    Thanks in advance guys!!
    Brian
    Brian Berneker replied 15 years, 1 month ago 3 Members · 7 Replies
  • 7 Replies
  • Vince Becquiot
    August 15, 2011 at 12:08 am
    Hi Brian,
    It’s not going to happen in the background, although that would make a great feature request.
    You can set your work area, Alt+[ and alt+] around the clip and go to Sequence > Render entire work area. I actually created a keyboard shortcut for that function using the Enter Key.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Brian Berneker
    August 15, 2011 at 12:50 am
    Is there no “render selected” option?
  • Vince Becquiot
    August 15, 2011 at 12:54 am
    I’m afraid not, see link above 🙂
    Vince Becquiot
    Kaptis Studios
  • Brian Berneker
    August 15, 2011 at 12:56 am
    Can you at least have it render low res (fast) proxies like AE can, maybe by adjusting the settings in the AE project itself?
  • Vince Becquiot
    August 15, 2011 at 1:08 am
    You could certainly render from AE to any format you like and use “replace with clip” in your sequence, but there is no “one Click” method. You can also change the sequence wide preview format.
    Often, simple AE like lower thirds or titles often don’t need rendering to play realtime, so i use dynamic link for those and render the rest to uncompressed.
    If you have a lot of clips, check out this Video Copilot preset.
    Vince Becquiot
    Kaptis Studios
  • Todd Kopriva
    August 15, 2011 at 1:27 am
    As Vince said, no.
    See this page for details of render commands.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Brian Berneker
    August 15, 2011 at 1:29 am
    Thanks Vince..
    I’ve already got the AE script (Kramer rocks BTW)
    I appreciate your help, and your responding so quickly.
    5 dings on the cowbell for this one!!
    Brian
