Activity Forums Adobe After Effects render active camera
  • render active camera
    Posted by Ron Labbe on June 27, 2009 at 4:00 pm
    I’ve got a couple of cameras set up, but when I add the comp to render queue, I thought the active camera would render, but it’s not so. I’ve got to, apparently, turn off the camera in the comp (if it’s above the camera I want). Is that correct?
    thanks
    ron labbe
    studio 3D
    Ron Labbe replied 17 years, 3 months ago 2 Members · 2 Replies
  • Andy George
    June 27, 2009 at 4:34 pm
    Hi Ron,
    It is so. The active camera is the topmost camera in your stack.
    Not to be confused with setting a camera from “active camera” to say “camera 2”
    in your composition window.
    This only allows you to view from the perspective
    of “camera 2” but does not actually change which camera is the active camera.
    Correct. Or move it lower in your stack.
    -Andy
  • Ron Labbe
    June 27, 2009 at 5:30 pm
    Yup, I thought the view was the active camera (with the yellow triangles, since I’ve got both camera views up).
    Now if I could only figure out why my rendered .avi’s don’t have sound! (that’s another thread).
    THANKS for quick response, Andy.
    ron labbe
    studio 3D
