Activity Forums Adobe After Effects Render a sequence wihout the 0000
  • Render a sequence wihout the 0000
    Posted by Dotan Stern on May 8, 2009 at 10:18 am
    Hi
    is it possible to render a sequence without the 0000 at the end?
    i want to render files calles for example test01 ,test02 , test03
    thanx
    Dotan Stern replied 17 years, 4 months ago 2 Members · 6 Replies
  • Bartek Skorupa
    May 8, 2009 at 10:36 am
    In the render queue select the name proposed by After Effects.
    If you chose to render as a sequence you should have something like:
    Comp 1_[#####].tga
    Change it to:
    Comp 1_[##].tga
    and you will have only two digits representing frame number
    Bartek Skorupa
    Warszawa, Poland
  • Dotan Stern
    May 9, 2009 at 8:12 am
    Thanx i tried that settings
    but i dont want any extra numbers after the name
    is it possible to do that in AE or any other software?
  • Bartek Skorupa
    May 9, 2009 at 10:20 am
    I don’t understand.
    Let’s say your comp is called “test”
    Its duration is let’s say 10 frames.
    If in render queue you use the name “test[##]” – your files will be called:
    test01, test02, test03 and so on.
    So it will be exactly what you described in your first post, right?
    You said you want to render a sequence, and want the files to be called test01, test02, test03.
    My solution gives you exactly this result.
    Could you please describe more precisely what your goal is?
    Bartek Skorupa
    Warszawa, Poland
  • Dotan Stern
    May 9, 2009 at 5:10 pm
    You were right sorry for the mistake
    i want the files to be 01 , 02 ,03
    no word before the numbers
    thanx
  • Bartek Skorupa
    May 9, 2009 at 5:13 pm
    So just call your output:
    Bartek Skorupa
    Warszawa, Poland
  • Dotan Stern
    May 9, 2009 at 9:24 pm
    That was easy
    thank you
