Activity Forums Maxon Cinema 4D render 50 fps to pal 25
  • render 50 fps to pal 25
    Posted by Dave Vickers on March 15, 2011 at 10:48 am
    Hi
    I’ve rendered an animation in C4d to animation codec at 50fps. The result at 50fps in Final Cut Pro is great, however I now want to reduce to 25 fps – I’ve tried a number of settings and combo’s but generally get lots of jittering in the high movement sections. I’ve read that it’s best to render to 50 fps in C4d and then render to fields in editing. How do I do this, or solve the jittering?
    Many thanks for your time – in advance
    Dave Vickers replied 15 years, 6 months ago 2 Members · 2 Replies
  • Brian Jones
    March 16, 2011 at 3:19 am
    Maybe JESDeinterlacer. It’s pretty good at deinterlacing but it has other functions one of which is interlacing. I haven’t run it through it’s paces for that but it could be worth a try. You can find it on macupdate.com
  • Dave Vickers
    March 16, 2011 at 8:22 am
    thanks
    that is a really brilliant tool – 25’s look great.
    all the best
    Dave
