Activity › Forums › VEGAS Pro › Render 4:3 as 16:9?
  • Render 4:3 as 16:9?
    Posted by Casey Menninger on December 16, 2019 at 4:14 pm
    Is there a way to take original 640 x 480 footage and preserve it as HD 1280 x 720? Or would that be 1280 x 960? I’m completely OK with black bars on either side of the picture, I just don’t want to distort the image.
    Is this possible? Or, am I wrong, naive, uninformed or just plain crazy?
    Francois Pénzes replied 6 years, 9 months ago 3 Members · 3 Replies
  • Francois Pénzes
    December 16, 2019 at 11:18 pm
    Hi Casey
    I will presume that it’s from older stock and was recorded at 640 X 480. That means that when you make it larger the quality and definition will drop. You can’t have HD quality if you don’t start with original HD material. You will be able to make it look better by using different plug-ins, Neat Video for example would help make it look less grainy.
    Cheers !
    PC Win 10 Pro 64-bit 16gb
    Ryzen 9 3900X 12 Core 4.60GHz
    Radeon RX 5700 XT
    Cameras: Canon XF305 + Canon XH-A1
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
  • Ben Longden
    December 23, 2019 at 11:16 am
    The current television standard is to display the 4×3 format in its entirety on the 16×9 screen, utilising the black pillars either side.
    That way you will feature the shot the way it was originally intended.
    If you subscribe to NEAT Video, i really can recommend it, as it does a wonderful job in cleaning and sharpening things up. But just find a Youtube tutorial first as its not intuitive.. and Im still a newbie with it after ten years of using it!
    Do unto others…
  • Francois Pénzes
    December 24, 2019 at 1:38 pm
    Hi Casey
    For some reason, a paragraph went missing in my last post.
    I was about another post I replied to a little while back.
    https://forums.creativecow.net/thread/24/1026164#1026165
    Cheers !
    Radeon RX 5700 XT
