Activity › Forums › Avid Media Composer › Renaming tracks
  • Renaming tracks
    Posted by Kurome on October 25, 2005 at 7:24 am
    Hello everyone!
    I have a problem with audio track naming and/or audio importing. I have timecode sync between DVCAM video and audio recorded on a harddrive. The harddrive recorder makes files BWF and all the tracks are separate files. So, when imported into Avid and synced with video, i get grouped clips with A1 and A2 as the reference from the DVCAM and all of the harddrive recorded audio as A1.
    I need a solution to get the audio to import or sync or be renamed as A3-A6. Can you do it with Composer?
    BTW. Is there an option to sync a the timeline?
    Kurome replied 20 years, 11 months ago 2 Members · 5 Replies
  • Michael Phillips
    October 25, 2005 at 11:43 pm
    If any of the tracks are the same, the result of an AutoSync will be a group clip. You can sync via the timeline;
    Cut picture and audio as a single event timeline
    Cut BWF as tracks 3+
    Highlught sequence in bin and do an AutoSeqeunce.
    Result is a subclip.
  • Michael Phillips
    October 25, 2005 at 11:44 pm
    I meant AutoSync, not AutoSequence.
  • Kurome
    October 26, 2005 at 6:03 am
    Thanks a lot!
    allthough it would be nice to just rename the tracks. Have to ask Avid if they would like to add this simple feature 🙂
  • Michael Phillips
    October 26, 2005 at 11:07 am
    Actually you are looking for a renumbering and not a renaming – the internal structure of the system needs to be aware of this…
  • Kurome
    October 27, 2005 at 6:19 am
    oh yeah, have to work on my english 🙂
