Activity Forums Apple Final Cut Pro Renaming selected clip (without affecting the main parent clip)?
  • Renaming selected clip (without affecting the main parent clip)?
    Posted by Xavier Paredes on August 21, 2020 at 3:55 pm
    I thought this would be possible but to my surprise, it’s not.
    Say for example I have some footage that’s 1 hour long. From within this 1-hour long footage, I select many sub-clips by using keywords. For argument’s sake let’s say I call the keywords 1 star, 2 stars, and 3 stars.
    Eventually, I wind up a lot of clips under each keyword category.
    Now, let’s say I want to further classify my sub-clips somehow so that they are easier to find. What I just tried doing is renaming a sub-clip —but low and behold when I did that it renamed all the other sub-clips (including the parent clip) to the same new name I was attempting to give this single sub-clip!
    Since now I have learned that I cannot rename sub-clips without affecting the rest, what do you folks do to organize all your many clips for ease of management?
    Any tips/techniques are appreciated.
    Xavier
    Xavier Paredes replied 6 years, 1 month ago 2 Members · 2 Replies
  • Kathy Murphy
    August 22, 2020 at 1:09 am
    On the timeline, convert each sub clip into a compound clip and rename it.
  • Xavier Paredes
    August 22, 2020 at 1:17 am
    Thank you. I did think of creating compound clips and I might wind up having to do this but I was hoping there was a more elegant solution. Creating compound clips feels more like a work around.
    Cheers!
    Xavier
