Activity Forums Adobe Premiere Pro Renaming .MTS files with Adobe Bridge Workflow
  • Renaming .MTS files with Adobe Bridge Workflow
    Posted by Dale Roberts on July 11, 2016 at 2:39 am
    Hi there,
    Been having loads of issues with thousands of .MTS files we have on our system. I have found I can rename them using Adobe Bridge.
    However in order to open the Stream Folder in Bridge I had to rename the AVCHD folder, then the BMDV folder and then I can open the Stream folder to rename the MTS files.
    I am just wondering if this is an okay practice going forward. My concern is that renaming the AVCHD and BMDV folders in the file structure might cause some issues especially since I am using the master copy of the SD card to do this.
    Really appreciate any thoughts.
    Cheers
    Dale Roberts replied 10 years, 1 month ago 2 Members · 2 Replies
  • Paul Neumann
    July 14, 2016 at 1:53 am
    Yeah, that might mess things up. I would use Prelude and do a Transfer with Renaming. Real quick for a simple rename of an AVCHD structure. I use File Name + Job Name all the time. An added benefit is you can pick just what shots you want and it will create an AVCHD structure with just those shots.
  • Dale Roberts
    July 14, 2016 at 11:40 pm
    Sounds interesting… Yes it made me slightly paranoid messing with the file structure.
    I will look into this for sure. Thank you,
