Activity Forums Adobe After Effects Renaming items with scripts
  • Renaming items with scripts
    Posted by Vahab San on November 5, 2018 at 7:06 pm
    Hello everyone
    Here is the situation:
    – I have an expression in comp A referring to comp B;
    – If I change the name of comp B from the project panel manually, expressions will update automatically;
    – If I change the name of comp B from the project panel by scripts, expressions will not update.
    How can I rename the comp B with script and expressions update automatically?
    Cheers
    Vahab San replied 7 years, 10 months ago 2 Members · 3 Replies
  • Walter Soyka
    November 5, 2018 at 8:23 pm
    Try it like this:
    var originalCompName = "Comp B";
    var newCompName = "Comp C";
    myComp.name = newCompName;
    app.project.autoFixExpressions(originalCompName, newCompName);
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Walter Soyka
    November 5, 2018 at 8:57 pm
    And to clarify what it does… autoFixExpressions(oldText, newText) will identify all broken expressions, do a search and replace within them (swapping out oldText for newText), and committing that change if it fixes the break.
    Walter Soyka
  • Vahab San
    November 6, 2018 at 8:07 am
    Walter
    Thank you very much.
    Worked perfectly. And again thank you for the explanation.
