Renaming in FCPX and finding the File name
Im not sure if I screwed up or if there is a solution. But I am new to FCPX and need help.
So here I was with a LOT of talking head bytes of the same fellow… so you can imagine the thumbnails all look the same. I was happily renaming the clips (in FCPX) with a single word that I can identify as a topic of what that byte was about (History, journey, crisis, etc). Now down the line, im beginning to get instructions (from the producer/director who has a copy of the footage as well) like use this line from this file (Original file name), etc.
I just assumed the original file name would be indexed by FCPX and show up in a search no matter what I name the clips. Unfortunately this is not the case. If I rename MVI_1043 to “Family”, searching for 1043 brings up nothing…. though “Family” is linked to he file “MVI_1043” in finder. I looked at the Info panel and saw there was no mention of the original file name.
So currently im now forced to go to finder, play back the clip, have a rough idea what I would name it on FCPX and hopefully find it there. It works in most cases, but as you can see, this is a very ineffecient process… and at this point, dont even care about the custom names I gave. If there is some way that the clips can be reverted back to their original file names, it would make my life so much easier.
I did not find any info regarding this in any other forums.
