Activity › Forums › Adobe After Effects › Renaming Effects
  • Renaming Effects
    Posted by Will Del mar on March 14, 2008 at 12:14 pm
    Hi!
    I was wondering how to rename an effect in After Effects – is it as simple as duplicating the effect and calling it something else? or is there an easier, less ‘brute force’ way to do it?
    I am trying to create my own presets that have custom names, to make it easier for me to re-use later on.
    Many Thanks!
    will
    David Eells replied 18 years, 6 months ago 3 Members · 5 Replies
  • Steve Roberts
    March 14, 2008 at 12:21 pm
    You can save presets and name them in the saving.
    Or if you want to name an effect in the effect window (F3) just hit return (if I recall) to highlight the effect name, and rename it. Then you can save the preset.
  • Will Del mar
    March 14, 2008 at 12:46 pm
    damn that was so freakin’ simple!
    Thanks so much for the ultra-speedy reply!
    regards,
    will
    actually, a second question: is there a way to create effects? Say i want an effect that is simply a slider bar and nothing more, to use in expressions in conjunction with other effects. How do I go about doing that?
  • David Eells
    March 14, 2008 at 3:49 pm
    Have you tried Effect>Expression Controls>Slider Control?
  • Will Del mar
    March 15, 2008 at 1:58 am
    Okay I apologise for my simple questions. I am still fairly new to this, and i think i should always post in the ‘basics’ topic!
    Thanks to steve and David for putting up with me patiently!
  • David Eells
    March 15, 2008 at 2:00 am
    No worries. This is the place to come for help.
