Renaming Clips in Timeline issue
I have several hour long interviews each done in one take which I long lined in the timeline. After adding an edit point after each answer I renamed each clip in the timeline with the question so it’s easy to find specific sections of the interviews.
The problem is when I drag those clips back into the Project panel they return to the source file name. Rather than having to rename them again is there anyway to see the new names in the Project panel?
