Activity Forums Apple OS X Renaming Boot Drive
  • Renaming Boot Drive
    Posted by Andrew Commiskey on August 1, 2007 at 3:07 pm
    If you Rename the Boot Drive will it screw up the operating system?
    A friend recieved his computer with his boot drive having a confusing name (he is just learning how to use a mac) and figured I would check before changing it.
    Drew
    Chaos is the beginning of everything.
    Andrew Commiskey replied 19 years, 1 month ago 3 Members · 3 Replies
  • 13 Create COW Profile Image
    13
    August 1, 2007 at 3:22 pm
    It will be fine, just reboot and repair the disk permissions after just to be safe.
  • Greg Serafin
    August 3, 2007 at 12:41 pm
    The only issue I ever had was wit backup.
    Backup worked on a “Macintosh HD” and after renaming created a new set fo the new name.
    On restore it did a restore to a NEW, HIDDEN volume in /volumes called with the old “Macintosh HD”.
    Took me a while to find it and manually move the restored files to where they should be.
    Advice: Do not rename if you have ran a backup!!!
    IQ
  • Andrew Commiskey
    August 4, 2007 at 11:52 pm
    Thanks all Just the info I was looking for.
    Drew
