Activity Forums Adobe After Effects Rename “Output To” property of render item through javascript
  • Rename “Output To” property of render item through javascript
    Posted by Dan Thomas on February 1, 2013 at 6:41 pm
    In my jsx code, I add a comp to the render queue. The “Output To” property defaults to the name of the comp. How can I access the “Output To” property (after it is in the render queue) to change the name of the output file? I know how do it manually, but how can I do it through scripting. I am using CS6. Thanks!
    Vishesh Arora replied 13 years, 7 months ago 2 Members · 1 Reply
