Activity Forums Apple Final Cut Pro Legacy rename GH2 clips
  • rename GH2 clips
    Posted by Aaron Walker on June 10, 2013 at 2:19 am
    I searched through the forum and didn’t see an answer to this. I am editing with footage from a Panasonic GH2, bringing it into FCP via log and transfer. The clips have designated numbers. Is there a proper way to rename the clips and will by doing so mess things up later along down the line (if I need to relink, exporting my final for sound mix, etc)?
    Aaron Walker replied 13 years, 2 months ago 2 Members · 4 Replies
  • Shane Ross
    June 10, 2013 at 2:44 am
    Rename in FCP, then go to the MODIFY menu and choose RENAME>File to match CLIP.
    Shane
    Little Frog Post
  • Aaron Walker
    June 10, 2013 at 2:47 am
    Thank you, Shane. So is the purpose of going to Modify to change the clip name in the capture scratch folder?
  • Shane Ross
    June 10, 2013 at 2:49 am
    The purpose is so that the clips in the CAPTURE SCRATCH match those of the clips. You don’t need to do this though…FCP will keep track if you only change the name in FCP.
    Shane
    Little Frog Post
  • Aaron Walker
    Got it. Thanks.
