Activity › Forums › Apple Final Cut Pro › Rename file to match clip?
  • Rename file to match clip?
    Posted by Noam Osband on May 10, 2017 at 3:36 pm
    Just checking: is there no way to do rename file to match clip in FCP X? I thought so, but perhaps I had it wrong. i have some files already imported and I want to do a batch rename that changes the actual file name too. Any easy way to do that in FCP X?
    Chad Greene replied 9 years, 4 months ago 3 Members · 2 Replies
  • Noah Kadner
    May 10, 2017 at 5:40 pm
    Nope- it will not rename at the Finder level. I recommend A Better Finder Rename for that.
    Noah
    FCPWORKS – FCPX Workflow
    FCP Exchange – FCPX Workshops
    XinTwo – FCPX Training
  • Chad Greene
    May 11, 2017 at 3:23 pm
    I just had to do this, only I also wanted the keywords added to the file names in the finder. It was a bit of a process that included “Producer’s Best Friend” and “A Better File Renamer”.
    1) Export XML of Event
    2) Run through “Producer’s Best Friend”
    3) Open in Excel (or in my case Google Sheets). Sort by original file name, then copy all FCPX clip names.
    4) Paste new FCPX clip names into Text Edit with one name per line.
    5) Use “A Better File Renamer” to completely rename the files based on the names on the text file.
    I did this to 37 events and 7,500+ clips last week with good success, though it took a while.
    Chad Greene : Mahoney Media : Minneapolis, Minnesota : 2×2.66 GHz 6-Core Intel Xeon, 12GB Ram, OS 10.11 FCPX, Kona-LHi
