Activity › Forums › Adobe Premiere Pro › Rename File name based off clip name
Posted by Isaac Brillant on June 30, 2014 at 2:15 pmhi,
Is there a function in CC similar to the “rename file name based off clip name” function in FCP?
thanksAbigail Bottrill replied 7 years, 6 months ago 8 Members · 12 Replies -
Alex Udell
June 30, 2014 at 4:13 pmI don’t think so….
and here’s why I think that may be the case…
in native editing, some formats require looking at folder structure (like MXF)…
renaming a file can create filename collision issues as well as linking problems when a “clip” as you see it is actually built from a number of sub components located in a folder set…..that’s my best guess anyway…
sorry…
Alex Udell
Editing, Motion Graphics, and Visual FX -
Yair Bartal
June 30, 2014 at 5:20 pmMay be, but…
Using “File/Project Manager…” you can set “Rename Media Files to Match Clip Names”.So?
Alex Udell
June 30, 2014 at 5:31 pmok….so then…. me = wrong 🙂
Alex Udell
Jon Hiseman
June 30, 2014 at 5:57 pmI sooooo want this too – right from the project window. When I log a series of clips in PPro I call them by a name I recognise anywhere in the project. When I archive the project I want those names in the Finder. So now I log in the Finder first, changing the names there. It still seems a no-brainer of a feature to me – and I’m long gone from FCP
I used to be Jon Hiseman but I’m feeling better now.
Isaac Brillant
June 30, 2014 at 6:02 pmThanks for the reply
But can you do the reverse, rename Clip Names to match Media Files?
Yair Bartal
June 30, 2014 at 6:36 pmNot that I know.
But why would you want to?
When you import a file, the clip name already matches the media File. -
Isaac Brillant
June 30, 2014 at 6:52 pmIn my case, the files were synced in the project before they had been correctly named. Now that they’re named correctly, I want the names of the clips in the project to match.
thx -
Francisco Garcia
February 25, 2015 at 10:09 amI would like to Rename Clip to Match File Name as well, which can be done in FCP.
A perfectly good situation that requires that in Premiere is the current case I’m dealing with.
Someone started a Premiere CC 2014 project using a combination of Lumix GH4 4K and 1080 footage, and some Panasonic AVCHD/MTS media. All without transcoding first.
They were complaining about constant crashes, which were being caused by the use of the original h264 files. I did a ‘Match Source’ conversion to ProRes using Prelude/Media Encoder and linked media to those new files. Now the project works and scrubs through the 4K like butter. However, the clip names still have the .MP4 and .MTS file suffix which I’d like to update to what the actual medial files are now, .mov.
A simple Rename Clip to File Name would be extremely helpful here. The only other way to do it is to update the name manually, or to right-click and Replace Media by pointing to the same source file and checking the Rename Clip to File Name box in the window that pop-ups. Still, this has to be done one file at a time, and is more time-consuming than renaming one-by-one in the bin.
Jon Hiseman
February 25, 2015 at 11:04 amFor those looking for a way to rename files in the Finder BEFORE importing into your NLE, look at this app for Windows or Mac:
https://www.filerenamer.com/It really does what it says on the tin.
jonhI used to be Jon Hiseman but I’m feeling better now.
Chris Whitmore
March 1, 2016 at 7:53 pmFrancisco,
I’m glad i found your note- I am literally working on the EXACT same workflow, with AVCHD fs100, gh4 footage and the need to update Clip names based on the new linked filenames.
Now that we have MOV files, we aren’t conforming, settings are great, and the editing is a million times easier/better/more efficient… except that the project has 156 versions of “00001.MTS” in various bins. blegh. on the file end, we have complete UNIQUE filenames just waiting to update into the clip names- but to no avail: there is no batch conversion in this direction it seems.
Has this ever been solved? Even by some third-party software or something? I know for sure that I haven’t learned it in the 6 or so years i have been fuddling with PrPro and it’s quirkiness. No disrespect, Premiere.
This would save my A** on an feature film project we are working on. Any ideas are welcome.
Thanks in advance.
Chris
