Activity › Forums › DaVinci Resolve › renaissance panels
renaissance panels
Posted by Charles Haine on December 22, 2011 at 2:48 pmI’m assuming the old Renissance 8:8:8 panels won’t work with Resolve, is that correct?
https://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=270878432247&ssPageName=ADME:B:SS:US:1123
thanks,
CharlesRobert Houllahan replied 14 years, 9 months ago 5 Members · 5 Replies -
Nuno Garcia
December 22, 2011 at 3:52 pmi think can work on Resolve Linux
But that one in eBay is not complete the picture just show the sec. control panelNuno Garcia
Illusion Color Grading -
Dan Moran
December 22, 2011 at 4:10 pmHey Guys,
The older style panels are only compatible with Resolve Linux and I think its only the 2k panels and above that are compatible but i’ll need to check with Peter or Rohit on that for you.
D
Dan Moran
DaVinci Application Specialist
Blackmagic Design EMEA -
Robert Houllahan
December 22, 2011 at 5:34 pmThose are older original 888 Panels which connect to the SGI O2 by a serial port. The newer style 2K panels have an ethernet connection and can be used with Resolve Linux. Because the older panels connect via serial there is no way to run them with Resolve.
-Rob-
Robert Houllahan
Director / Colorist
Cinelab Inc.
http://www.cinelab.comMAHC-PRO 6-Core 3X GTX285 20Tb SAS Wave Panel Panny 11UK SDI Plasma.
Dwaine Maggart
December 22, 2011 at 7:52 pmWhile the panels in the Ebay link are indeed serial connected panels which will not work with Resolve as Rob mentions, network connected style panels were also used with 8:8:8 DUI systems, and those panels would work with a Linux Resolve, as both the DUI and 2K network style panels are electrically identical, and only have different key-caps and labeling.
Dwaine Maggart
Blackmagic Design DaVinci Support -
Robert Houllahan
December 23, 2011 at 3:31 pmWith the catch-22 being that you can only buy the Linux license with the new panels now, which is really not a bad deal….
-Rob-
Robert Houllahan
Director / Colorist
Cinelab Inc.
