Removing wind noise.
Posted by Frank Manno on August 24, 2005 at 6:59 amAnyone know of a good enough quick way to remove wind noise from audio?
Doesn’t have to be perfect..
-Frankie
Mary Waitrovich replied 21 years, 1 month ago 3 Members · 3 Replies -
Mary Waitrovich
August 24, 2005 at 11:28 am“good enough, quick way”: put the offending audio clips on their own track. Add graphic EQ and turn down the low frequencies until it starts to affect the voice. That will take a lot of it out.
Mary Waitrovich
UW-Madison -
Rick Wise
August 24, 2005 at 5:20 pmI’ve found that fixing wind noise is next to impossible. Too many of the frequencies are mixed in with the voice. I’ve tried noise reduction and graphic eq and noise gate. The best I can do is slightly improve the sound, but not much. After that the voice gets very tinny.
Love to hear from someone who has figured out a way to do this.
Rick
Rick Wise
director of photography
Oakland, CA
http://www.RickWiseDP.com
email: Rick@RickWiseDP.com -
Mary Waitrovich
August 25, 2005 at 12:48 amWell, the real way is to record the audio with a boom mic with one of those expensive furry windjammers on it so you get very little wind noise to begin with. All noise reduction programs work based on frequencies, some work better than others because they filter more selectively.
