removing wet noises in speech
Posted by Laura Gruszczynski on August 1, 2008 at 7:42 pmOkay, I searched the forum and could not find anything about removing the annoying saliva sounds from an interview. I gave the subject water during the shoot, like I always do, and she drank it, but you can still hear dry mouth noises when she speaks. Help! This is annoying the daylights out of me. Shooting it over is out of the question. Any ideas, filters, etc would be greatly appreciated.
Lauragruszla
Andrew Williamson replied 18 years, 1 month ago 6 Members · 10 Replies -
Steve Wargo
August 2, 2008 at 7:42 amAre you talking about the clicks and snaps?
In he future, have apple slices ready for your talent. They cleanse the mouth to stop the clicking.
Steve Wargo
Tempe, Arizona
It’s a dry heat!Sony HDCAM F-900 & HDW-2000/1 deck
5 Final Cut (not quite PRO) systems
Sony HVR-M25 HDV deck
2-Sony EX-1 HD . -
Ty Ford
August 2, 2008 at 2:19 pmHello Laura and welcome to the Cow Audio Forum,
Once they click, they click. I’m wondering, though, if these impulse sounds can be removed with a de-clicking software normally used to remove clicks from records,
Haven’t tried it. Maybe someone else has.Do you have de-clicking software?
Regards,
Ty Ford
Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
Watch Ty play guitar -
John Fishback
August 2, 2008 at 11:20 pmI’ve tried click removal software in Pro Tools and it doesn’t work well. Most of the time removing mouth noises is a manual job. It’d be easier to do it in an audio editor than video. Just make sure you don’t pull the ends of the edit together. This will cause the audio to go out of sync. Replace the noises with room tone so the overall length of the audio isn’t changed.
John
Dual 2.5 G5 4 gigs RAM OS 10.4.8 QT7.1.3
Dual Cinema 23 Radeon 9800
FCP Studio 5 (FCP5.1.4, DVDSP4.1.1, Comp2.3, STP1.1, Motion 2.1.2)
Huge U-320R 1TB Raid 3 firmware ENG15.BIN
ATTO UL4D driver 3.50
AJA IO driver 2.1 firmware v23-28
Pro Tools HD w 192 Digital, SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neuman U87s, Genelec Monitors, PrimaLT ISDN -
Ty Ford
August 3, 2008 at 5:32 amOr redraw the waveform and flatten the clicks.\
Regards,
Ty Ford
Reid Caulfield
August 3, 2008 at 4:18 pmI have Declick software that works beautifully on “lip smack”, so it can indeed work. It’s true the Pro Tools stuff isn’t do great for this. Otherwise, manual declicking or editorial works but is time consuming.
Reid C
Steve Wargo
August 10, 2008 at 2:28 am[Reid Caulfield] “I have Declick software that works beautifully on “lip smack”,”
Reid, Do you have anything that fixes bad acting?
Steve Wargo
Tempe, Arizona
2-Sony EX-1 HD . -
Ty Ford
August 10, 2008 at 3:47 amI do. Good casting and good talent.
Regards,
Ty Ford
Reid Caulfield
August 10, 2008 at 4:38 amTalent. Good one. LOL. I think there’s always a case to be made for total dialog down, atmospheric music up, silence-is-deafening type of sound editorial as a cure for bad acting. Tell everyone it was an artistic decision & that you’re really happy with the way it turned out. Or recast the part in post as someone who speaks a foreign language, dub that language in, cut in side & back-of-head shots only, then add English subtitles. Voila! Bad acting is a thing of the past!
Reid C
Ty Ford
August 10, 2008 at 2:37 pmYou want to see bad acting?
We watched the movie “Zacharia” last week just for kicks.
Regards,
Ty Ford
Andrew Williamson
August 16, 2008 at 12:59 amI’ve had really good results using iZotope RX, selecting the upper frequencies on the spectrogram and applying a heavy declicker.
We had a very similar problem with this talking head interview that came in for dub, where the guy speaking sounded absolutely disgusting! Had no joy applying filters without too many artifacts and must have tried a thousand other tricks and snips within my DAW, but going out into RX and being able to be frequency specific with the filtering really did the trick.
Hope this helps!
Andrew
