Activity › Forums › Apple Final Cut Pro Legacy › Removing video effect.
Posted by Bruce Rawlings on August 19, 2008 at 6:45 amI’m new to FCP from Avid and cannot find way of removing a cross dissolve or video effect from the video timeline – I know it must be a simple procedure, but……
Rob Hargreaves replied 16 years, 2 months ago 6 Members · 7 Replies -
Don Greening
August 19, 2008 at 7:59 amHighlight the clip you want to remove the effect from and choose “Remove Attributes” from the Edit menu. To remove a cross dissolve just highlight it and hit the delete key. I can’t remember if it’s important for both of the above but make sure you have the selection tool active otherwise you may not be able to select the cross dissolve to delete it.
– Don
David Thayer
April 16, 2009 at 8:42 amI have a clip onto which I have stretched the cross dissolve over the entire clip. I can neither delete the cross dissolve nor move the clip. If I select the clip I can only delete the entire clip. The right-click attributes are different when the cross dissolve covers the entire clip. Zooming in doesn’t help either. I cannot find a handle on which to shorten the cross dissolve. What am I to do?
Tom Wolsky
April 16, 2009 at 11:28 amDouble click on the transition to open it into the viewer. Shorten it there so you can grab it.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Rob Hargreaves
June 14, 2010 at 9:25 amHi
Is there a way to remove a video effect (Color Corrector 3-way) from a clip I accidently added (dragged) it to in the browser window as there is not option to “Remove Attributes” as you would from the timeline?
Thanks -
David Roth weiss
June 14, 2010 at 2:50 pmIf you double click and load the clip with the filter into the viewer, you can go into the filter tab, click on the filter you wish to remove to highlight it, and hit delete to remove the offending filter.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
EPK Colorist – UP IN THE AIR – nominated for six academy awards
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Rob Hargreaves
June 16, 2010 at 3:11 pmThanks for the reply David, I’m using FCP 7.02 and I followed your instructions and it’s doesn’t work. I am using a Macbook Pro so I’ve tried CMD+BackSpace, Option+Backspace, Ctrl+Backspace, Shift+Backspace & Backspace while the filter is highlighted in the Viewer but I’m seemingly unable to remove/delete it.
Any further thoughts would be appreciated.
Rob
