Activity › Forums › VEGAS Pro › Removing transitions from Slideshow
  • Removing transitions from Slideshow
    Posted by Cg208cm on October 18, 2005 at 9:39 pm
    How can I remove a transition once I have added it. If I double click it, it just opens. I can’t seem to find a “delete” icon for transitions.
    also, would it just be easier for me to stick with overlapping the images rather than adding transitions?
    Wes
    Terje A. bergesen replied 20 years, 11 months ago 4 Members · 3 Replies
  • Edward Troxel
    October 19, 2005 at 12:15 am
    Overlapping the events is how I do add the transition (i.e. crossfade). One solution to remove a different transtion would be to replace it with a dissolve. However, that’s not exactly the same as a crossfade. To make it a crossfade once again, put the cursor on the transition and press / on the numeric keypad. This will revert it back to a crossfade.
    Edward Troxel
    JETDV Scripts
  • Gilles Pialat
    October 19, 2005 at 5:56 am
    Also, you can replace a Transition by a Cut by pressing ‘CTRL + /’.
  • Terje A. bergesen
    October 21, 2005 at 2:42 am
    In addition to *that* you can open the transition, and to the right of the transition chain, there is a remove button, just next to the question mark. Click it and the transition is gone from your clip.
    Terje A. Bergesen
