Activity Forums Adobe After Effects Removing tracking points
  • Removing tracking points
    Posted by Jose Moris on June 20, 2008 at 3:28 pm
    I recently shot an interview with a jib in front of a green screen. I wanted to track the background with the jib motion so I used black tape as a the track point. I guess I didn’t think this through enough, because removing that track point is proving to be a little more involved than I would like it to be. Is there any quick and easy way to remove the tracking point that doesn’t involve a whole bunch of key frames? Help me, help me…somebody help me!?
    Michael Morlote replied 14 years, 7 months ago 3 Members · 3 Replies
  • Peter O’connell
    June 21, 2008 at 4:29 am
    Hi, I would use the sampleImage expression (in the Layer General tab of expressions) to gather data near the tracking marker if you really want to do it without keyframes.
    Pete O’Connell
  • Jose Moris
    July 28, 2008 at 5:20 pm
    Well, I just figured out a solution. I keyed the image and then added a green solid. I reduced the scale to cover just the black cross(tracking point). I then motion tracked the point to the solid. I then made the keyed layer and the solid into a precomp. Finally, I added a key to the precomp and keyed out the green solid. I hope that all makes sense. It works perfectly and is real quick. Let me know if you need me to explain it a little better.
  • Michael Morlote
    February 2, 2012 at 7:18 am
    Do you think you would be able to make a tutorial? That would help me a lot.
