Activity › Forums › Adobe After Effects › Removing track in dolly shot
Posted by Jim Bachalo on May 10, 2014 at 2:44 amI have a straight dolly shot
https://vimeo.com/94716098
pw musicI need to remove the floor track somehow.
What would be the ‘best’ way to do this in AE?
You should follow me on Twitter here. My latest work
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Jim Bachalo replied 12 years, 4 months ago 4 Members · 6 Replies -
John Cuevas
May 10, 2014 at 12:53 pmI think the “best” way would be to get a clean plate of the floor without dolly tracks in a higher resolution, and camera track/planar track that to your move. If that option isn’t possible, try CC Wire Removal
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Walter Soyka
May 10, 2014 at 6:47 pmIt looks like it’d be pretty straightforward to do in Ae with a little help from Ben Rollason’s Projection script [link].
Maybe it’s a worthwhile candidate for the Mocha Pro Remove module [link?
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Jim Bachalo
May 10, 2014 at 7:35 pm -
Jim Bachalo
May 11, 2014 at 5:07 pmOnly problem I’ve found is that I can’t seem to get a 3D camera tracker solve on the floor. Wall on right, no problem. Probably the lack of contrast?
Guessing I have to use Mocha… can anyone walk me thru creating a proper track using Mocha? Just use the spline tool with default settings and export or?
Ross Shain
May 14, 2014 at 7:53 pmmocha should be able to track the floor pretty easily. You will want to track from end to beginning and draw a shape around the floor plane and avoid any foreground elements such as the instruments, etc. Then you export your track data.
There are multiple ways to attack your problem from compositing perspective:
1. Track in mocha AE and apply a “painted” patch to the track data. Because you will want to make you patch in perspective, you will want to use “Align Surface” button before exporting mocha data.
2. Track in mocha AE and use the MochaImport+ to stabilize a precomp of the floor, do your paint work, than remove the stabilize. (mamoworld.com has great tuts).
3. OR mocha Pro has remove module that could track in a painted clean plate and match the lighting shifts for a more realistic composite.
best,
RRoss Shain
Imagineer Systems
http://www.imagineersystems.com -
Jim Bachalo
May 14, 2014 at 8:36 pmThanks!
My guess is Mocha is the ‘best’ option for this particular shot. Could not get the built in 3d tracker to solve the floor for some reason.For now have resorted to a somewhat kludgy and imperfect solution but it gets me in the ballpark
I created a luma matte with blurred edges isolating the track
The used this matte in conjunction with offset copies of the floor layer
