Activity Forums Apple Final Cut Pro Legacy Removing timecode from client’s mpg
  • Removing timecode from client’s mpg
    Posted by Lynette Gilbert on February 3, 2009 at 2:55 am
    I just got some files sent to me for my freelancing … and had something I’ve never run into before.
    The mpg has a timecode on it. I cannot edit mpgs in FCP (if someone knows how to do this, please tell me!) because no audio shows up. I converted the files to DV files, which I’ve done before.
    However, I have NO idea how to remove the timecode! Is this something I can do before I convert to DV, and if so, how?
    Lynette Gilbert replied 17 years, 7 months ago 4 Members · 6 Replies
  • Lynette Gilbert
    February 3, 2009 at 2:58 am
    I tried to upload an example, but I was having issues. Sorry. It’s been a long day.
  • Walter Biscardi
    February 3, 2009 at 3:01 am
    You can use MPEG-Streamclip (Free) to convert to a Quicktime format.
    You mean it has a timecode burned in window on the video? Then you blow it up to crop out the TC, but usually this means someone else has already performed a rough cut and the client is going somewhere else. Or you are cutting from a window burn file for some reason.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Rafael Amador
    February 3, 2009 at 4:19 am
    [Lynette Gilbert] ” I converted the files to DV files, which I’ve done before.”
    Use MPGStreamclip and convert your .mpg’s to DV50 or better codec. Ideally 8b Unc.
    There is nothing to get rid of the burnt-in TC.
    The only solution is the one pointed by Walter.
    Probably will destroy the picture.
    Rafael
    http://www.nagavideo.com
  • Lynette Gilbert
    February 3, 2009 at 4:29 am
    That’s what I thought. I will email him and see if he can delete it from the original project.
  • John Fishback
    February 3, 2009 at 3:32 pm
    You could crop the frame as needed and place it on a graphic background. That way you don’t have to blow up the image and lose quality (which is already taking a hit coming from mpg).
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Lynette Gilbert
    February 3, 2009 at 5:18 pm
    Great idea – since he’s against a black background, I can just match the color in Motion …
