Activity Forums Adobe After Effects removing the green X
  • removing the green X
    Posted by Corillo181 on May 22, 2007 at 7:24 pm
    so there is this green X in all the effects i be using in after effects. at first i thought it was something that after effects wouldn’t render, but when i was done with a test project, there was the green x on my rendered movie, i want to know how i turn this off?
    Andrew Yoole replied 19 years, 4 months ago 4 Members · 5 Replies
  • Steve Morris
    May 22, 2007 at 7:53 pm
    It sounds like you are using a non registered plugin.
  • Corillo181
    May 22, 2007 at 7:55 pm
    i’m using the normal plug in that the program comes with.
  • Dan Ebberts
    May 22, 2007 at 8:41 pm
    You must have the demo version of a plugin installed. What effects are you using in your project?
    Dan
  • Corillo181
    May 22, 2007 at 8:56 pm
    i am not even sure about if plugin or what i just went to the presets and added a background presset they all com with a green x what kind of plug in do i need to have for it to work fine becuas ei just installed it.
  • Andrew Yoole
    May 23, 2007 at 2:08 pm
    A lot of the Background Presets in AE use Cycore FX. The Cycore FX plugins use a seperate installer which is included on your AE installation CD.
