Activity Forums Adobe Media Encoder Removing Stock Presets
  • Removing Stock Presets
    Posted by Jeff Herring on June 29, 2017 at 8:55 pm
    When I go to render in AME I have some custom presets that I use and they are nicely placed at the top of the list. There are others that are in the middle of a loooooooooooong list of presets and adobe doesn’t making scrolling to them easy. I understand that I can make a custom but there are some that I use so infrequently that I don’t need it at the top so they will also be at the top but I also want to remove presets that I know I’ll never use like “SD for Tivo Series II” or “SD for Nook”.
    AME doesn’t let you delete stock preset from within in the program.
    I found the presets folders @ C:\Users\\Documents\Adobe\Adobe Media Encoder\11.0\Presets and edited the file there I also deleted the whole file and AME will put the Nook and Tivo presets back. It even replaced the file.
    So how do I remove the presets permanently? I’ve already exported them to a backup folder in case I should ever need them.
    Jeff
    Chris Wright replied 9 years, 2 months ago 2 Members · 1 Reply
  • Chris Wright
    June 30, 2017 at 12:15 pm
    try renaming them 1. something 2. else. the number will push to top in premiere’s dropdown at least. then write protect the file and change permissions.
