Activity Forums Adobe Audition Removing static from audio interview
  • Removing static from audio interview
    Posted by Bob Wilson on June 28, 2022 at 5:16 pm
    Hello!
    Recently I was given audio interviews which were recorded nearly 30 years ago. When i listened to the interviews, I found that there is quite a bit of static noise. Think of it like the interviews were recorded on vinyl and the record wasn’t taken care of. While I can make out the speech, the layer of static is distracting. How can I remove/reduce the static?
    Kevin Carlson replied 4 years, 1 month ago 2 Members · 1 Reply
  • Kevin Carlson
    August 12, 2022 at 1:30 am
    Noise reduction software. I use izotope rx, and it is excellent.
    I think Adobe has some options built in as well.
