Activity Forums Avid Media Composer removing spot with Paint Effect
  • removing spot with Paint Effect
    Posted by Avi Lev on June 23, 2013 at 3:56 pm
    I’m trying to remove a spot from the frame using the Avid Paint Effect.
    But it’s not so easy on handheld shots. The spot moving fast all over the frame. I tried the Tracking and for some reason it didn’t work.
    Any Idea how I can fix this problem?
    Avi Lev replied 13 years, 2 months ago 2 Members · 3 Replies
  • Michael Phillips
    June 23, 2013 at 4:15 pm
    Have you tried scratch removal instead to see if that works any better?
    Michael
  • Avi Lev
    June 23, 2013 at 6:46 pm
    THANKS MICHAEL, I’ll try and let you know. Does it have tracking tool as well?
  • Avi Lev
    June 25, 2013 at 8:54 pm
    I tried with the scratch removal with out much success. Since the spot on the screen is bouncing as fast as ping pong ball the tracking tool is not fast enough to capture the speed. This is how I understand it.
