Activity Forums Apple Final Cut Pro Removing Sharpness in Final Cut Pro X
  • Removing Sharpness in Final Cut Pro X
    Posted by Nicolas Vallejo on August 10, 2013 at 2:24 pm
    I shoot with a 5D MKIII, and always use a Technicolor Cinestyle profile, which removes contrast, saturation, and sharpness from the image so I can add it in post.
    I shot a sequence without all these elements present except for sharpness. Need to take it down quite a bit. Is there a better way of achieving this than gaussian blur?
    Fernando
    Nicolas Vallejo replied 13 years ago 2 Members · 2 Replies
  • David Battistella
    August 13, 2013 at 9:52 am
    Try taking it into Resolve, then have some nice softening tools in there that will get the edge off.
    IN FCP X use .02 value to soften the image a bit. Work in small fractions instead of with the slider. a .02 pixel blur is often used to soften digital photography.
    David
    ______________________________
    https://www.davidbattistella.com
  • Nicolas Vallejo
    August 13, 2013 at 4:48 pm
    Use a .02 value, where, exactly?
