Activity Forums Blackmagic Design Removing pulldown on capture?
  • Removing pulldown on capture?
    Posted by Julian Clarke on June 7, 2005 at 10:32 pm
    Hi Guys,
    I have a decklink extreme. From what I understand, one of its listed features is the ability to remove 3:2 pull down on capture, through VITC metadata. Now, what I don’t understand is how to do this. In the audio video settings window, you get a little box to tick for Advanced pull down removal. But I want to remove standard 3:2 film pull down, not advanced pull down. How do I go about doing this? Or does this feature actually mean that it can remove advanced pull down on capture and not standard 3:2 pulldown?
    Cheers
    Julian
    Adam Levine replied 21 years, 3 months ago 2 Members · 1 Reply
  • Adam Levine
    June 8, 2005 at 4:38 am
    Just use the NTSC 23.98 BlackMagic Setup, and have the correct setting in the Decklink System Prefs
