Activity › Forums › Apple Final Cut Pro Legacy › Removing Pulldown in an MPEG-2?
  • Removing Pulldown in an MPEG-2?
    Posted by Rafael Amador on November 27, 2009 at 5:39 am
    Dear friends,
    I’ve got an old MPEG-2 clip that is 29’97 (up to the QT Info).
    My intention is to use it with 25fps footage.
    The clip is from the early 50’s so I guess was shoot in 16mm.
    is there any way to get back the original 24fps?
    Thanks in advance for your help.
    Best,
    rafael
    http://www.nagavideo.com
    Christian Hart replied 16 years, 6 months ago 4 Members · 5 Replies
  • Shane Ross
    November 27, 2009 at 8:24 am
    YOu have to convert it to an I frame format first…ProRes, DV…something. THEN you can reverse telecine… GOP formats don’t reverse. Then after you get it to 24fps, conform to 25fps with Cinema Tools.
    Shane
  • Rafael Amador
    November 27, 2009 at 8:59 am
    Shane,
    Thanks a lot for your help.
    I know all this from the theory, but I’ve never put my hands on.
    no problem about the conforming, but what about the different “Pulldown patterns’ that I can find?
    Would that affects me?
    Thanks again.
    rafael
    PS: You are up early, don’t you?
  • John Pale
    November 27, 2009 at 6:36 pm
    Since this footage was converted at some point to a GOP format (MPEG 2), I think it\’s unlikely you will ever be able to get back to the original \”true\” 24 frames. You will likely see frame blending using every pulldown option because the MPEG encoding has irrepairably altered the original frames….some of them no longer exist…regardless of whether you convert back to Pro Res or some other I Frame format.
    Won\’t hurt to try though.
  • Rafael Amador
    November 28, 2009 at 2:15 am
    Hi John,
    Thanks for your advice.
    A nice opportunity to explore “the wonderful world of the pulldown” for a PAL-land boy:-)
    The clip is very old and interesting so I guess people wouldn’t notice much if would play choppy, but you know our silly perfectionism.
    Cheers,
    Rafael
  • Christian Hart
    March 15, 2010 at 2:27 pm
    Hi Rafael,
    did you ever get this working?
    I am trying to do nearly the exact same thing – use old stock footage
    originally shot on film (WW2 battle stuff) given to me as 29.97 quicktimes but not as mpeg2 – instead with an animation codec.
    i’d like to use them in my 25p DVCPro HD project (which we are going to make both PAL and NTSC DVDs from btw)
    From reading about this on the forums the solution seems to be as shane says – convert to iframe (compressor for this? I seem to get “Failed” messages)
    Then I can supposedly use cinema tools (as you’d expect i’m getting temporal compression errors if i try it straight away) to make it 25p…
    Has anyone got any pointers for things i may have missed?
    I’m using 10.6.2.
    compressor 3.5.1
    fcp 7.0.1
    all the best
    c
