Activity › Forums › Apple Final Cut Pro Legacy › Removing power and phone wires.
Posted by Warren Elliott on August 24, 2010 at 4:03 amHi all. Okay so I’m still learning. Doing a shot with a 1800 building however it has power lines running to it from the right hand side and we cannot get them physically removed. I run Final Cut Studio 2. Any suggestions on how I can post edit the lines out. See attached image at
Yes the car will not be there.
Best of Health
WarrenjelliottWarren Elliott replied 16 years ago 5 Members · 7 Replies -
Chris Tompkins
August 24, 2010 at 1:09 pmDo you have Adobe After Effects?
This is what I would use.
Keyframe, remove.Chris Tompkins
Video Atlanta -
David Roth weiss
August 24, 2010 at 2:04 pmIs the shot going to be static or moving? Static you’ll be able handle yourself. If it’s not locked off you’d best either hire a VFX person ASAP or master motion tracking yourself ASAP. And, Autodesk Combustion would be a better tool than AE.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
EPK Colorist – UP IN THE AIR – nominated for six academy awards
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Warren Elliott
August 24, 2010 at 8:11 pmThanks Guys. One shot static. Just don’t have those additional software packages you both suggested. Is it not possible in Color or Motion then?
Best of Health
Warrenjelliott -
Michael Gissing
August 24, 2010 at 9:53 pmColor is a grading tool. Motion can do this job. You could also do it in FCP but Motion is much better.
Warren Elliott
August 25, 2010 at 2:30 amCool thanks. Looks like its time to hit the motion study books and work out how. Cheers
Best of Health
Warrenjelliott -
Ben Holmes
August 25, 2010 at 1:09 pmI would think you could duplicate the footage in Motion, mask out the wires with the pen tool, invert the mask so you have a layer with just the wires, then move the mask up a little so you have a layer with just sky of a similar colour. Then move that layer back down so the wires are covered by Sky. Feather the mask or blur the layer a little to cover any gradient joins. Should be OK.
The area on the front of the building might require more work – if the shot is static, you could make a layer in Photoshop using clone tools using a clean bit on the wooden panelling.
If the thought of any of this makes your head spin, hire a pro for half an hour – it’s a very quick fix.
Ben
Edit Out Ltd
FCP Editor/Trainer/System Consultant
EVS/VT Supervisor for live broadcast
RED camera transfer/post
Independent Director/Producerhttps://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
Warren Elliott
August 25, 2010 at 8:36 pmThanks Ben I’ll just put the me head back into the right spot. Look at it then make a call. Cheers
Best of Health
Warrenjelliott
