Activity Forums AJA Video Systems Removing Playback Output options
  • Removing Playback Output options
    Posted by Matt Gerard on October 17, 2008 at 2:36 pm
    Is there any way to decrease the number of options in the FCP Video Playback drop list in the Audio/Video settings box? I hate having to scroll through 35 settings when I actually only use 2 or 3. I’ve talked to AJA support, they seem to know less about it than I do.
    MAtt
    Its more fun to ride a slow motorcycle fast than a fast motorcycle slow…
    Matt Gerard replied 17 years, 10 months ago 2 Members · 4 Replies
  • Jeremy Garchow
    October 17, 2008 at 5:59 pm
    What Kona do you have and what version of the software?
    Jeremy
  • Matt Gerard
    October 17, 2008 at 6:14 pm
    Kona LH, Control Panel version 5.1
    Just looked, and see there’s a 6.0 update. I’m downloading that now. Will that help me out any?
    Matt
  • Jeremy Garchow
    October 17, 2008 at 6:27 pm
    In the setup tab of the Kona Control panel of the new software, you can select which presets load. I think this feature is available for the LH, I’m not sure.
    Basically it will narrow it down to NTSC based frame rates (29.97/59.94/23.98)
    or film based (24.0/60.0/30.0)
    or PAL (25/50)
    Select what you need and deselect the others, then launch FCP.
    It cuts down on the clutter a bunch.
    Jeremy
  • Matt Gerard
    October 17, 2008 at 6:30 pm
    Brilliant!!! This is what I was looking for. Should update all my other software and see what else I’m missing…
    Matt
