Activity Forums Adobe Premiere Pro Removing out points from stills before editing
  • Removing out points from stills before editing
    Posted by Mike Weber on August 9, 2012 at 9:26 pm
    Hello – I am editing my first project in Premiere CS6, after many years using Final Cut 7.
    I edit a lot of slide lectures, where I often have 100+ stills to edit into the sequence. My usual method is to mark in & out on the sequence, and then edit in the still.
    Problem is, in Premiere the stills automatically have in/out marks (as predetermined by the default duration set in Preferences). On every single edit, Premiere brings up a “Fit Clip” dialogue box, prompting me to chose which in/out point to ignore. To me, the sequence in/out is most important, and so I have to click “Ignore Source Out Point” every time. This is really slowing me down, having to answer this question over and over again.
    In the case of a 4 point edit like this, Final Cut 7 assumed that the sequence in/out was dominant, and just ignored the source out point. Can I set up Premiere the same way? Otherwise, my only alternative is to remove the out point of each slide before editing to the timeline. Just one extra keystroke, I know, but it adds up. If this is my only option, is there at least a way to delete the out points from a group of stills en masse?
    By the way, this is only a problem with stills Movie files seem to import without pre-marked in/out points.
    Thanks very much –
    Mike Weber
    UCTV
    https://www.uctv.tv
    Bobby Cullipher replied 13 years, 11 months ago 2 Members · 1 Reply
  • Bobby Cullipher
    September 5, 2012 at 12:57 am
    Not sure how to resolve this issue, but I find it very inconvenient as well. To speed up the process, I created a keyboard shortcut to delete the in, out and both in/out points. So, after you double click the image to load it into your source monitor, press the shortcut you need and life should be a little easier/faster. I think there is already a shortcut for these commands but I wanted them on specific keys.
    Hope this helps.
    – Laptop –
    Dell Precision M6600 (2012)
    NVIDIA Quadro 3000
    16GB RAM
    i7 2860M
    750GB HD RAID 0
    Windows 7 Pro
    – Older MacPro –
    FCP 6 | 6.0.6
    Mac OS X 10.6.5
    2X3.2 GHz Quad-Core Intel Xeon
    4GB 800 MHz DDR2 FB-DIMM
