Activity › Forums › Adobe After Effects › Removing objects frame by frame in videos
Posted by Tim Drexler on November 11, 2009 at 3:30 amIs After Effects the best way to remove objects on a frame by frame basis from my videos? I’m using Final Cut Express on my IMac. I was hoping I could do it in Photoshop Elements, but I’m told I can’t.
Tim Drexler replied 16 years, 9 months ago 4 Members · 4 Replies -
Theo Veltman
November 11, 2009 at 5:15 amDepends what you’re trying to remove. After effects has a tracker which can be used to track an object then using a mask you can remove said object. If you’re referring to dust and scratches then maybe photoshop would be best. to I’m not sure if Photoshop Elements can load quicktimes though so you’d have to export a frame sequence which you would then need to make back into a movie before re importing to Final Cut (bit of a hassle).
Steve Roberts
November 11, 2009 at 2:40 pmYes. The process is called rotoscoping. Look for tutorials on the web.
Tim Drexler
November 15, 2009 at 2:39 pmThanks, Steve. I checked a rotoscoping tutorial and it looks like it will do the trick. However, as I understand it, I will only be able to use this technique if, initially, the sequence does not contain the object (In this case a person I wish to remove from the sequence) and then the object moves through the sequence. Looks like you can then target them for removal from the sequence and retain all of the character of the background. Is that correct?
