Activity Forums Apple Final Cut Pro Legacy removing name from audio clip in time line
  • removing name from audio clip in time line
    Posted by Chuckfaz on February 4, 2007 at 1:40 pm
    Ok, FCP 101 but…
    I have looked and googled for a way to turn off the clip name for a clip in the time line to no avail so how do you do it so all you can see in the waveform?
    Best,
    Chuck
    Charles Fazio
    Managing Partner
    Mark Rivera’s NewYork State of Mind Entertainment Group (NYSOM-EG)
    Entertainment
    Kim Rowley replied 19 years, 7 months ago 4 Members · 4 Replies
  • Tom Wolsky
    February 4, 2007 at 2:42 pm
    Hi Chuck,
    I’m afraid there isn’t. The only way is to open it into the Viewer, which isn’t really the same thing I know. You could go to feedback and add your name to the list of those requesting this feature. Might be nice if you toggle waveforms on the clip names would disappear and vice versa.
    All the best,
    Tom
  • Chuckfaz
    February 4, 2007 at 2:58 pm
    Thanks, Tom. I leave the feedback thing to others. Been there, done that.
    Best,
    Chuck
    Charles Fazio
    Managing Partner
    Entertainment
  • Andy Mees
    February 4, 2007 at 3:41 pm
    if you do find yourself editing the audio in the viewer, due to the far greater detail available from that view, then an extra trick is to pull the audio tab off the viewer window and drop it down onto the timeline window … gives you a bit of extra space.
    cheers
    Andy
  • Kim Rowley
    February 5, 2007 at 5:55 pm
    I’ve encountered the same problem…When extensively tweaking audio levels, etc. I enlarge the track view to its maximun height. That way at least the clip names appear above the waveform and don’t cover it.
    Dual 2.7 GHz G5, 4GB RAM, ATI Radeon 9650, Xserve RAID, AJA IO, 2 20″ Cinema Display, FCP 5.1.2, OS X10.4.8
