Activity Forums Maxon Cinema 4D Removing missing plugins from scene
  • Removing missing plugins from scene
    Posted by Ryan Kehn on November 25, 2011 at 6:20 am
    Hello all,
    I’m having net render issues stemming from a phantom plugin in my scene.
    I didn’t personally add any plugins, but there may have been one in a model/scene i merged into the project. Regardless, I don’t have any plugins on my system, so I get the following error when I open the project.
    Several plugins used in this scene are missing.
    Saving may cause loss of plugin data!
    Plugin ‘Group’ (ID 1016210)
    It doesn’t seem to effect my scene as long as I’m rendering on my machine alone. However, it gets in the way in Net Render (net render won’t even begin rendering the scene on any machine).
    I don’t know of anyway to locate which objects in my scene may be making reference to said plugin. I’m assuming deleting that reference will get me good to go, much like deleting or replacing a missing texture.
    Anyone have any tips? I’m desperately trying to get this scene rendering as it’s a bit of a beast and want to waste as little time as possible to get it going.
    thanks!
    Ryan Kehn
    Senior Media Designer
    Stadium Management Company, LLC
    Denver Broncos Football Club
    ryan.kehn@broncos.nfl.net
    Jamal Qutub replied 13 years, 5 months ago 3 Members · 2 Replies
  • Adam Trachtenberg
    November 26, 2011 at 4:23 pm
    I would start by looking in the render settings as some plugins will create a post effect. That can be cleared by removing the effect.
    If that doesn’t do it I would scroll through the Object Manager and look for any tags or objects that you don’t recognize, which may be plugin tags.
    Lastly, I’d go through the materials and make sure that there aren’t any plugin shaders present.
    You might also check the console window to see if there’s a message indicating the plugin that’s trying to load.
  • Jamal Qutub
    March 27, 2013 at 2:49 am
    I believe this error:
    Means you may have a Riptide Pro group tag on an object. Sometimes when importing .obj files from a Riptide export have these, just delete the group tags.
