Activity › Forums › Adobe After Effects › Removing Lens Smear in 1 Clip
  • Removing Lens Smear in 1 Clip
    Posted by Brock Humphrey on October 25, 2015 at 6:03 am
    Greetings,
    There was a slight smear on my 24mm lens for the one establishing shot I got for this scene. It’s the lighter area right above the blonde girl – you can see where the green of the flowers and bushes gets lighter.
    How can I remove this?
    Thank you.
    Tudor “ted” jelescu replied 10 years, 11 months ago 3 Members · 2 Replies
  • Chris Wright
    October 25, 2015 at 9:02 am
    duplicate the layer, add a feathered mask, set transfer mode to soft light.
    You might need more than 2 with different opacities and mask sizes.
  • Tudor “ted” jelescu
    October 26, 2015 at 10:42 am
    Chris gave you a good way of doing this. I would use a duplicate layer with a feathered mask but apply a color correction using Curves/Levels or Colorista to try and match the contrast and saturation of the rest of the clip. The trick will be to find the right shape and feather for the mask.
    Tudor “Ted” Jelescu
    Senior VFX Artist
