Activity Forums Adobe Premiere Pro Removing keypoint interpolation
  • Removing keypoint interpolation
    Posted by Lars Sommer on November 29, 2017 at 8:04 pm
    Hi.
    I´ve been trying for hours to make this simple thing work, and I dont think I know enough on the subject to fully understand what I am doing, so I hope you can help ☺
    I want to slide an image into the picture, and afterwards out, with a “custom easy ease in” movement.
    So I have to keyframes with the exact slide-in motion I want:
    Now I would like to copy these to keyframes, so I can keep the exact movement, and just change the image position on the keyframes, so the image can slide out of the picture the same way it came in.
    Problem is, when I do this Premiere adds some wierd movement on the image and some interpolation(?) between the keyframes. How do I remove this so it´s just linear, and now wierd movement?
    I´ve tried right-clicking the keyframes and change the interpolation, dragging and the handles and what not, but I cant get rid of this auto-generated movement.
    Thanks alot for your help 🙂
    Lars Sommer replied 8 years, 8 months ago 3 Members · 8 Replies
  • 8 Replies
  • Lars Sommer
    November 29, 2017 at 9:33 pm
    Hi Dave.
    Thanks alot for your answer.
    I´ve tried to copy the image to another track, then copy the original keyframes and paste them to the newly image, but the result is the exactly same :/
  • Andy Patterson
    November 30, 2017 at 5:20 pm
    I think you are using bezier instead of linear. You have to right click on the key frame to switch to linear.
  • Lars Sommer
    November 30, 2017 at 8:10 pm
    I´ve tried to change the interpolation to linear, but it does not help.
    Please see this gif on how I do it. Maybe you can catch me in doing something wrong ☺
  • Lars Sommer
    November 30, 2017 at 8:13 pm
    I have just dragged a jpg image into the timeline. 4 seconds duration, and I have not manipulated it yet.. So I dont think it´s because of unwanted keyframes..
  • Andy Patterson
    November 30, 2017 at 8:56 pm
    Are both temporal and spacial set to linear?
  • Lars Sommer
    November 30, 2017 at 9:14 pm
    Spatial, yes. If i set the Temporal interpolation to linear, it totally changes the interpolation velocity on the existing keyframe, but I still cant get rid of the weird interpolation between the two keyframes.
  • Todd Perchert
    December 1, 2017 at 10:44 pm
    Wish I could see what was going on with your image, because what I see is you copying and pasting two keyframes that will result in the same exact transition, not reversing. You would need to rearrange the last two keyframes for a reverse in direction. Or am I not seeing something???
  • Lars Sommer
    December 2, 2017 at 9:37 am
    Thanks alot for your answer! I don´t know what happened, I´ve tried adjusting the keyframes to the correct positions after they we´re copied but the problem was the same. And since then I have just focused the interpolation problem without adjusting the position. But right now I´ve adjusted the positions and it works!
    So thanks alot for your help! 🙂
