Activity › Forums › Avid Media Composer › removing key frames
removing key frames
Posted by Lisafer on January 29, 2006 at 1:53 amHow do you remove key frames
Promopunkk replied 20 years, 6 months ago 4 Members · 3 Replies -
Chaz Shukat
January 29, 2006 at 11:06 pmSimply click on the keyframe triangle icon so that it turns pink, letting you know it’s active, and then hit delete. You can also shift-click on multiple keyframes and then hit delete. Also, did you know that you can click on a keyframe, hit copy and then paste that keyframe’s attributes to another keyframe? Also, did you know that one keyframe provides 100% of the daily requirements of 7 essential vitamins and minerals? 😉
Jon Zanone
January 31, 2006 at 4:33 am[Chaz Shukat] “Also, did you know that one keyframe provides 100% of the daily requirements of 7 essential vitamins and minerals? ;)”
I knew there was a reason I’d gained weight. Now I can have all the doughnuts I want. Pesky keyframes…
Jon
Promopunkk
March 6, 2006 at 1:08 pmplus, when you can hit the alt button you can then drag the keyframe to a new position.
