Removing judder from panning shots (image stabilization issues)
I am experiencing some serious judder problems while shooting long pans on my Canon C300 with a Canon EF 70-300mm f/4-5.6L IS USM and a Miller Compass 20 fluid head. We were pulling them really smooth (the Miller fluid head is amazing), but you can see these tiny jumps in the footage. Right now I suspect it was the fact that we had image stabilization active on the lens while trying to pull the pans (totally sucks). Image stabilization tried to keep the image centered while we slowly pulled across the landscape creating small, but still perceptible, little judders in the footage. It could be something else, but we were getting similar problems using the same lens with image stabilization activated on an entirely different C300 body and fluid head. Right now the Warp Stablizer in Premiere Pro CC (Smooth Motion/100% Smoothness/Subspace Warp/Stabilize, Crop, Auto-Scale) is not completely doing the trick. Those little ticks and jumps are killing me. You can see the Warp Stabilized footage alongside the original footage at this link:
Can I do something else with the Warp Stabilizer to make this even smoother? Are there third-party plugin solutions or techniques that can be used in After Effects? Is there a temporal smoothing process that works on judder of this type? I really want to get rid of the judder without having to reshoot various locations. It’s small but noticeable. Any tips or thoughts would be greatly appreciated.
The original footage was shot at 1920×1080, 50MBPS, 23.976fps, Progressive and exported for Vimeo at 1280×720, 23.976fps, Progressive VBR, 2 Pass, Max 5MBPS. I am using a MacBook Pro Retina 2.6 GHZ Intel Core i7 running Adobe Creative Cloud.
