Activity Forums Adobe Photoshop Removing JPEG artifacts
  • Removing JPEG artifacts
    Posted by Mark Algmae on July 7, 2023 at 1:20 pm
    Hi everyone, so contrary to the last post on this forum that wanted to add jpeg artifacts, I am looking for ways to remove them! I have a bunch of old photographs that have artifacting on it, and I am looking to fix them up. I used the trial on Lets enhances upscaler which did a pretty good job, but before I go further with that it got me wondering about photoshops capabilities in removing jpeg artifacts. I am pretty good with the program, but by no means an expert, so could anyone give me some pointers, or if there are other options for removing artifacts. Any input if much appreciated, thanks!
    Brie Clayton
    replied 2 years, 11 months ago
    5 Members · 4 Replies
  • Hector Vera
    July 9, 2023 at 5:16 pm
    Go to Filter -> Neural Filters and then go to where it says “JPEG Artefacts removal. If its not yet downloaded, go ahead and download it. Its a pretty quick process. Then check the Strength settings for this. Highly recommend it to always set it to high 🙂
    Here is the source where I learned to do it recently myself for visual context: https://www.youtube.com/watch?v=XcWR6B5_W88
    Hope it helps!
  • Biju Toha
    August 14, 2023 at 5:04 am
    One tool is the Reduce Noise filter. This filter can reduce noise in an image, including JPEG artifacts. To use the Reduce Noise filter, follow these steps:
    Open the image in Photoshop.
    Go to Filter > Noise > Reduce Noise.
    Set the Strength slider in the Reduce Noise dialog box to a moderate setting.
    Check the Remove JPEG Artifacts checkbox.
    Click OK.
  • Anni Gerard
    September 25, 2023 at 11:48 pm
    can someone give me a step by step guide on how to remove wires/cables in a photograph and make it look compltely natural using photoshop. I’m a novice and failing to do so properly…
    (FYI i click pictures of buildings…)
  • Brie Clayton
    September 27, 2023 at 5:35 pm
    Hello Anni! Could you give us an example? I usually use the Clone tool to carefully blot out most unwanted objects such as lines, replacing them with the correct nearby colors, then perhaps smoothing things over with the Blur tool. But it would be helpful to see what you are working with since each situation requires its own “finesse”.
