Activity Forums Adobe After Effects Removing items from the video
  • Removing items from the video
    Posted by Rickpgh on August 24, 2006 at 12:19 pm
    I am editing a training video regarding firefighting. I quite new to AE. What I need to do in this video is remove a rope that is attached to the fireman as he is scaling a building. My first thought was to clone it out. When I started doing this, I noticed that as the frames proceeded and I continued cloning, I was getting “multiple” clones as the frames progressed. My initial question is, was cloning the right approach? If so, how do I prevent the multiple clones? If not, what approach should I take? Any help on this would be appreciated.
    Rickpgh
    Al replied 20 years ago 2 Members · 1 Reply
  • Al
    August 25, 2006 at 10:12 am
    this depends on a lot of things, mostly, does your shot move?
    generally the process involves creating a ‘clean plate’ – so make a clean frame without the fireman in it at all. just the building. put this layer under your original shot, then either paint the rope out using the clean plate as a source – or simply use a mask with feather to eliminate the rope, seeing through to your clean plate.
