Activity Forums Apple Final Cut Pro Legacy Removing interlace flicker
  • Removing interlace flicker
    Posted by Patrick Stapleton on August 2, 2010 at 12:12 am
    I have some video that was captured from an old VHS tape. A music clip from my old band back in the 80’s. When I view this .dv file is looks fine in Final cut however when I render it into a DVD using iDVD and play it through my television all the highlight material flickers terribly. I’m assuming this is an interlacing issue.
    Is there an easy fix for this?
    Kai Cheong replied 16 years, 1 month ago 3 Members · 3 Replies
  • Rob Grauert
    August 2, 2010 at 5:04 pm
    How are you looking at a .dv file in FCP? I don’t believe that’s a supported format. Did you capture using iMovie and then bring the clip into FCP? Not a good idea.
    Rob Grauert, Jr.
    http://www.robgrauert.com
    command-r.tumblr.com
  • Patrick Stapleton
    August 3, 2010 at 2:56 am
    I’m looking at the file in FinalCut now (V7.02) the details are:
    Frame Size 720 x 576
    Vid Rate 25 fps
    Compressor DV-PAL
    Data Rate 6.9 MB/sec
    Aud Rate 48.0KHz
    Aud Format 32-bit Floating Point
    I can view this in the viewer and it looks good. I’m chopping a bit of the front and outputting as DV-PAL 48kHz, when view this new file in Quicktime it look good. However when I take into iDVD and encode into a DVD and playback the DVD I get nasty flicker on the highlights.
  • Kai Cheong
    August 14, 2010 at 4:24 pm
    I’m not familiar with encoding via iDVD, but when I used to use Toast Titanium to quick encode DVDs, I noticed the default setting is for NTSC material – maybe that’s causing your PAL video to have its fields reversed?
    If you’re familiar with Compressor and DVD Studio Pro in your FCS3, I’d recommend you author your video via that method. Gives better quality.
    Kai
    FCP Editor / Producer with Intuitive Films
    https://kai-fcp-editor.blogspot.com
    Now ‘LIVE’! Check Out The Intuitive Films Blog @ https://intuitive-films.blogspot.com
    At Intuitive Films, We Create: TV Commercials, Documentaries, Corporate Videos and Feature Films
    Visit us @ https://www.intuitivefilms.com
    MacBook Pro 2.4GHz | 4GB RAM | FCP 5.1.4 | Mac OS X 10.5.7
    8-Core Intel Mac Pro 2.26GHz | 8GB RAM | FCP 6.0.2 | Mac OS X 10.5.6 | 3.0TB CalDigit VR | 2 x 24″ Dell S2409W
